How to Clear System Data on iPhone and iPad
how to clear system data on iphone
There are a few good reasons to clear system data on an iPhone and iPad. You can free up storage space, optimize performance, resolve software issues, enhance battery life, improve system stability, and more. And you won’t even be losing anything – most of what you’ll be clearing out is junk or redundant data.
But there is more than one way to delete system data on an iPhone and iPad – in fact, there are 4. We’ll cover them all in this article. Read on!
What is System Data on iPhone and iPad Storage
System data on iPhone storage or iPad storage refers to various files and data that the operating system needs to function properly. They typically include your device’s system files, caches, log files, firmware, diagnostic data, and other similar backend components.
System files are usually put to work in the background and are not directly accessible or viewable by users (by design). But you can get an idea of how much storage is taken up by system data. We’ll show you how.
To view system data on your iPhone or iPad:
Step 1. Open the Settings app on your iPhone or iPad. Then, scroll down and tap General.
Open general tab in settings
Step 2. Tap iPhone/iPad Storage.
iPhone storage tab in general settings
Step 3. Note the System Data section. It shows the amount of storage used up by system data. As you decrease the system data on your iPhone using the methods we outline below, that change will also be reflected in the menu.
System section in settings
It’s a good idea to keep a close eye on this menu from now on so you have an idea of when you’re close to your device’s storage capacity. When your iPhone storage is full (or iPad storage), it may no longer work as expected and you may have to suddenly delete data on the spot to use a feature.
Why is System Data So High on iPhone or iPad
As we just mentioned, system data on your iPhone or iPad is made up of important files that keep your iPhone operational. It can be frustrating to see system files eat up a huge chunk of your storage space, but they keep your device running and are actually designed to make life easier for you.
To better understand how iOS uses your storage space for its own use, here are the most notorious “space invaders” and the role they play on your device:
Type of dataDescription
📲 iOS updatesiOS updates take up a lot of storage space due to new features and enhancements, additional asset libraries and resources, and even bug fixes and improvements. Most of these actions require adding more files to the system, which your device has to accommodate.
🗃️ Cache and temporary filesCache and temporary files can reach several gigabytes in size under certain circumstances. A good example is your browser cache storing high-definition headers from a frequently visited website in order to load its pages faster.
🗄️ Logs and diagnostic dataDepending on your settings, iOS may be collecting various logs and diagnostic data in order to troubleshoot issues and/or send them to Apple for feedback. Logs don’t take up much space on their own but can quickly add up.
🧩 Pre-installed appsWhile not strictly considered “system data”, the pre-installed apps on your iPhone or iPad (e.g. Messages) take up storage space just like any other app.
How to Clear System Data on iPhone or iPad
We’ll show you how to clear system data on an iPhone or iPad using 4 different methods. We suggest you go through all of them to get rid of system data completely. They’re scattered throughout different components of your device but we made sure to cover all bases.
The exception is Method 4, which causes data loss. While it’s the most effective way to delete iPad system data (or iPhone system data), treat it as a last resort and don’t use it if you don’t need to.
Method 1: Clear Your iPhone or iPad’s Browser Cache
If you want to reduce system data on your iPhone or iPad, your device’s browser cache/s should be the first to go. Browser caches can easily bloat up your iOS system data size as they sometimes save heavy assets like high-resolution images.
By saving these assets locally, your device can open websites much quicker. However, there are scenarios where browser caches store assets from websites that you don’t visit anymore. In this case, your iPhone system data is huge but you don’t even need any of its files.
The process varies only slightly depending on which browser you’re using. We only covered Safari and Google Chrome, but you should be able to follow along with most mainstream browsers.
The steps below may potentially delete important user cache data like saved passwords. Make sure you have a copy of the account details associated with your browser.
To clear browser cache using Safari:
Step 1. Open the Settings app. Then, scroll down the page under Settings and tap Safari.Select Safar in settings
Step 2. Tap Clear History and Website Data and confirm the action when prompted.Clear data button in Settings
To clear browser cache using Google Chrome:
Step 1. Open the Chrome app. Then, tap on the 3 dots in the bottom-right corner of the screen.Open menu in chrome app
Step 2. Tap History.Open history in Chrome
Step 3. Tap Clear Browsing Data…Select Clear Browsing Data in History
Step 4. Select Cookies, Site Data and Cache’d Images and Files. Then, tap Clear Browsing Data at the bottom of the screen.Clear Data selection in Chrome
Step 5. Tap Clear Browsing Data again to confirm the action.Clear Browsing Data Confirmation Prompt
Method 2: Reset Network Settings
Another way to clear system data on an iPad or iPhone is to reset the device’s Network Settings. It can be beneficial for several reasons – you can free up storage space (though minimal), troubleshoot network issues, improve network stability, and more.
Make sure you have your network details written down somewhere! This feature will clear out all of your network data.
To reduce system data on your iPhone or iPad by resetting its Network Settings:
Step 1. Open the Settings app. Then, scroll down the pagel under Settings and tap General.Select General in Settings
Step 2. Scroll down to the bottom of the page and tap Transfer or Reset iPhone/iPad.Select Transfer in Settings
Step 3. Tap Reset at the bottom of the page.Select reset in Settings
Step 4. Tap Reset Network Settings and enter your passcode (if you have one) to confirm the action.Confirm reset in Settings
Method 3: Reset All Settings on Your Device
Resetting all the settings on your iPhone or iPad is a great catch-all troubleshooting step that can resolve software-related issues like crashes and other abnormal behavior. It can also fix conflicts in your settings that have built up over time.
It basically resets everything to default EXCEPT your data, which remains 100% intact.
To erase the system data on your iPhone or iPad by resetting all settings:
Step 1. Open the Settings app. Then, scroll down the page under Settings and tap General.Select General in Settings
Step 2. Scroll down to the bottom of the page and tap Transfer or Reset iPhone/iPad.Select Transfer or Reset iPad in settings
Step 3. Tap Reset at the bottom of the page.Select reset in iPad settings
Step 4. Tap Reset All Settings and enter your passcode (if you have one) to confirm the action.Reset confirmation in settings
Method 4: Factory Reset Your iPhone or iPad
Method 4 is the most comprehensive way of clearing system data on an iPhone or iPad (as well as all other data). It completely wipes everything from the device, including any persistent issues or malware or viruses that may be affecting its performance. Junk files, of course, aren’t spared.
To free up system data on your iPhone or iPad by performing a factory reset:
Step 1. Open the Settings app. Then, scroll down the pagel under Settings and tap General.Select general in Settings
Step 2. Scroll down to the bottom of the page and tap Transfer or Reset iPhone/iPad.Select transfer in General
Step 3. Tap Erase All Content and Settings at the bottom of the page.Erase content selection in settings
Step 4. Confirm the data that will be deleted and tap Continue.Confirmation prompt in Settings
Follow the wizard to proceed with resetting your iPhone or iPad. Your device will reboot a few times – make sure it’s plugged into a wall adapter until the process is complete.
How to Effectively Manage System Data
If you find yourself urgently needing to clear system storage on an iPhone or iPad, your device hasn’t been running in optimal condition. Otherwise, iOS’ housekeeping should have been able to handle it (iOS tries to automatically delete system data taking up space when it thinks it needs to).
To avoid this situation in the future, here are some easy tips to help you maintain your device system’s data hygiene:
  • Keep your device updated. iOS updates usually include performance improvements and bug fixes. The latest iOS versions are much better at managing system data on your behalf.
  • Regularly clear your browser caches. Your browser caches can build up quickly with loads of data you might never need. iOS tries its best to do some housekeeping, but manually clearing your device’s caches will go a long way.
  • Monitor storage usage. Checking your storage usage from time to time will help you get ahead of potential build up.
  • Avoid sketchy Profiles. Profiles have their own configurations of settings, restrictions, and features that can be applied to your device (e.g. by a school or organization). Make sure you trust the Profile!
  • Regularly backup and Factory Reset your device. This may sound counterintuitive to “avoiding” having to clean up your device. However, Factory Reset is a great way to maintain device hygiene especially after it goes through multiple iOS updates. Just make sure to back up your data first!
If you’re trying to increase storage space on your device, consider using iPhone cleaner apps. While they can’t really delete system data on your iPhone or iPad, they can help you efficiently clean up unwanted data. This often includes user data that you don’t regularly get to access, such as app caches or temporary files (which can hog a lot of resources over time).
To summarize, clearing the system data on your iPhone or iPad can help free up storage, resolve bugs or glitches, and improve performance. There are different methods to lower system data on your iPhone or iPad depending on what kind of data you want to clear. Just make sure that you back up any important files before using the more drastic ones (like Factory Reset).
