Moshi Unveils The Revolt Duo, Can Charge Two iPads In The Car
If you frequently take road trips, you know how important your iPad is when you’re in the passenger seat. However, the device’s battery doesn’t last forever, and standard automobile Lightning adapters charge the iPad slowly as they only offer 5W of power output.
However, Moshi has just fixed this issue with the Revolt Duo. This car charger features two 10W USB ports that will can up to two iPads as fast as a standard iPad USB wall adapter will. If you don’t have two iPads, you can also use the second USB port to quickly charge an iPhone or other USB powered device.
If you’d like a Revolt Duo for your car, expect to drop $45. A Lightning cable is included with purchase.
