Deal: The Cable Key Is An Ingeniously Small iPhone Charging Cable
If you’re tired of lugging around long messy cables just so you can charge your iPhone while on the go, you’ll want to check out the Cable Key. It’s a small, lightweight iPhone charger cable about the size of a normal thumb drive. It’s designed to hang on your keyring, so it goes everywhere with you and it uses a high-speed USB 2.0 connection to quickly charge your device using any USB port.
Normally it would cost you $40 to snag this super portable iPhone charger, but for a limited time you can grab it for just $14.99. That’s a small price to pay for the convenience of owning this device. You can grab it here.
