Conquer Your Next Power Outage With The Power Outage Cube Light
Face it: power outages really suck. Unfortunately, there’s really not much you can do during them aside from hanging out at a local coffee shop (while buying plenty of drinks, of course) and charging your gadgets there. However, once you return home at night and realize that your power is still out, you need an arsenal of flashlights at your disposal and a nice backup battery for your iPhone. Fortunately, the Power Outage Cube Light has you covered.
This cool new gadget is essentially a charging dock that docks four included rechargeable flashlights. The center of the dock illuminates when power is cut, so you can easily find the dock in the dark. On the front of the device, you’ll also notice that it has two built-in USB ports. One of these USB ports can be used to charge an iPhone or other USB device while your power is out by way of the dock’s internal battery. The second USB port can be used while power is still flowing to the device.
The Power Outage Cube Light will run you $120.
